#1 2019-06-30 18:25:53
kapqa
Upgrade from Debian Wheezy to Devuan Jessie
Hello ,
i am currently running Debian Wheezy and am wondering if there is an upgrade path for me to switch to Devuan Jessie.
The current Desktop Environment is Gnome3 and i have Radeon Fglrx Driver installed (which i would deinstall prior due to suggested non-compatibility with Jessie).
Thanks
#2 2019-06-30 18:48:05
Re: Upgrade from Debian Wheezy to Devuan Jessie
kapqa wrote:
Hello ,
Yes, there is!  You'll find documentation here.  I'm not 100% sure if you can go directly from Wheezy or need to upgrade to Debian Jessie first.  Gnome is a no-go so the suggestion is to switch to Xfce before the upgrade.  Devuan has the same firmware available as Debian.
Note that in sources.list, jessie-updates is no longer in use for old-stable so would throw errors.
#3 2019-07-01 00:39:42
Yes, you can go from debian wheezy directly to devuan jessie. I've done it several times in the past year. (always with xfce)
Do it now if you're going to do it. You have about a week before jessie is retired. I heard that july 6 is the projected date.
#4 2019-07-01 15:46:21
kapqa
Thanks, i am still considering to upgrade.
The Wheezy is Overall very satisfactorly Distribution, but sometimes i would Need newer packages like libc6 or other.
One Problem i noted with XFCE on Jessie is Problem with multimonitor as XFCE would not allow easily to extend the monitor onto two Monitors.
Has this issue been solved? What About switching to KDE?
Could i then from Jessie go straight to Beowulf or would i Need to upgrade to Ascii first?
#5 2019-07-01 15:57:57
Experiment with xrandr and/or lxrandr.  That should get things set up for you.
KDE is available as an option - if you like bling and bloat.
Absolutely not.  You need to go through ascii to get to beowulf.
#6 2019-07-01 16:45:12
kapqa
Is the same command needed as with Debian?
aptitude install ~t^desktop$ ~t^kde-desktop$   ?
Thanks
#7 2019-07-01 19:54:11
Thanks
If that's the aptitude equivalent of apt-get install task-desktop task-kde-desktop then it should work.
#8 2019-07-02 14:51:56
kapqa
Thanks ,
i might try that out sometime later.
with a fresh install on Devuan Ascii (Graphical Install) the KDE would not install alongside XFCE. It did abort when choosing both options.
Only choosing default install would install normally.
#9 2019-07-02 15:16:30
I was in a bit of a panic over this date but then found this nugget in a post on FDN:
Jessie support is now handled by the LTS team rather than Security team. You should be OK until June 30, 2020.
https://wiki.debian.org/LTS
Evidently June 6 is not a hard cutoff date for jessie so we have a little breathing room.
#10 2019-07-02 18:42:02
Yes but you only need the second part, task-desktop is a dependency of task-kde-desktop.
#11 2019-07-03 00:09:13
golinux wrote:
in a post on FDN:
Thanks! I forgot about that - 2020.
(posted from devuan jessie)
#12 2019-08-01 23:31:20
erdos
i received the following error when i tried upgarde from wheezy to devuan jessie
root@debian:~# apt-get update
Ign http://pkgmaster.devuan.org jessie/main Translation-en
Ign http://pkgmaster.devuan.org jessie-security/main Translation-en_US
Err http://pkgmaster.devuan.org jessie-backports/main i386 Packages
  404  Not Found
Ign http://pkgmaster.devuan.org jessie-backports/main Translation-en_US
Fetched 7,587 kB in 15s (487 kB/s)
W: GPG error: http://pkgmaster.devuan.org jessie Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY BB23C00C61FC752C
W: GPG error: http://pkgmaster.devuan.org jessie-security Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY BB23C00C61FC752C
W: Failed to fetch http://pkgmaster.devuan.org/merged/dists/jessie-updates/main/binary-i386/Packages  404  Not Found
W: Failed to fetch http://pkgmaster.devuan.org/merged/dists/jessie-backports/main/binary-i386/Packages  404  Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
root@debian:/home/erdos# ^C
#13 2019-08-02 11:14:45
apt install devuan-keyring
And say 'yes' to the scary warning.
Remove jessie-updates and jessie-backports from your sources. They no longer exist.
#14 2019-08-02 15:15:08
erdos
thank you, it's a success upgrade to Devuan Jessie after ignoring warning messages.
#15 2020-02-09 21:09:37
kapqa
I tried to do this today (have several computer running Debian Wheezy 64Bit or Powerpc) with a quite fresh installation on Gnome3 + plus some packages installed
The error when going directly from Wheezy to Devuan Jessie would be
sudo apt-get dist-upgrade
Building dependency tree
Calculating upgrade... Failed
 gir1.2-gnomebluetooth-1.0 : Breaks: gnome-bluetooth (< 3.8) but 3.4.2-1 is to be installed
 gnome-bluetooth : Depends: gir1.2-gnomebluetooth-1.0 (= 3.4.2-1) but 3.14.0-2 is to be installed
                   Depends: obexd-client but it is not going to be installed
 gnome-settings-daemon : Depends: libgnome-desktop-3-2 (>= 3.4.0) but it is not going to be installed
                         Depends: libpackagekit-glib2-14 but it is not going to be installed
 gsettings-desktop-schemas : Breaks: gnome-settings-daemon (< 3.10.0) but 3.4.2+git20121218.7c1322-3+deb7u3 is to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
So it seems more intelligent to update to Debian Jessie first, or to remove Gnome3 altogether and then upgrade directly to Devuan Jessie (and skipping Debian Jessie altogether)?
#16 2020-07-18 13:55:55
kapqa
Hello ,
the link to upgrade to Jessie is no longer accessible.
Please make it accessible,
Thanks.
#17 2020-07-18 13:59:41
kapqa
#18 2020-07-18 15:02:58
nixer
For future and possible current reference
What link is that?  What address are you using in your /ect/sources.list file?
#19 2020-09-25 16:10:47
kapqa
Hello ,
i would need to upgrade this laptop to jessie from debian wheezy.
here is the sources.llst
deb http://pkgmaster.devuan.org/merged jessie main
deb http://pkgmaster.devuan.org/merged jessie-updates main
deb http://pkgmaster.devuan.org/merged jessie-security main
deb http://pkgmaster.devuan.org/merged jessie-backports main
the following error is occureing when doing
sudo apt-get update
W: Failed to fetch http://pkgmaster.devuan.org/merged/dist … 4/Packages  404  Not Found [IP: 54.36.142.183 80]
#20 2020-09-25 17:27:44
Jessie reached End of Life in June and the packages have been archived. Use the following line in sources.list to get jessie packages. You only need the one line, There are no more security fixes or updates for jessie.
deb http://archive.devuan.org/merged jessie main
After you finish upgrading to jessie, you might want to upgrade to ascii, which is the current Oldstable.
#21 2020-09-26 07:52:35
Ascii or beowulf are both good options.  just dont stay on wheezy or jessie. smile
Favourite operating systems: Hyperbola Devuan OpenBSD
